I wanted more light and came up with a bracket design that I put together.
It is an aluminum plate that has been bent slightly down for the front and up for the back to make it about level when mounted to the ROPS.
The ROPS leans back a bit so thats why it had to be bent in a press brake.
Then I took a piece of 2" aluminum channel and bolted it to the plate front edege. The lights are mounted to the channel and hang down as you can see.
On back I mounted a small beacon on top.
It is painted ROPS gray and is attached to the ROPS with square U bolts.
No welding or drilling on the ROPS
Each has its own fuse and switch.
Works great and looks good.. IMO
