Years ago we got a perkins 3544 that we put a pump on, it works good but if you run it too hard the stack can start to glow which I caught before it went too far. Also burns a bit extra fuel... not much just enough to be detected by a tech.
So one day I looked up the seriel number... TW33168U675270J
First 2 numbers stand for "Turbo" and "water cooled" plus the tag said T6.....
So this engine is supposed to have a turbo, so now I'm trying to find a kit to do it. I do see 2 plugs on that side one that I'm 95% sure is low enough for oil return and the other is an oil out port.
Also usually the turbo is a 4 bolt and this exhaust is 3 bolt. I see plugs for oil pressure and a small one for oil return down low.
It's very strange but now I'm trying to find a good turbo to match it to get the full power and efficiency. I'm guessing this wouldn't need a waste gate or anything odd like that
