I've search and can't find what I'm hoping to find!
I'm I the only one that has ever been able to bend both my "Main Frame brackets" on a BX2370 while trying to mount the LA 243A loader? The first one "left side" was last fall but I was able to with help get the loader mounted. So this year, I watched and read again and tried again. Well I made the mistake of putting one pin in thinking that the other side would hit the cradle and the pin line up! Big mistake! the loader swung to the side and because the pin was in place, the other main frame got bent! Both sides are only slightly bent, but when you look you can tell.
So at this point, I'm not able to get either side pinned before the other side jumps totally out.
1. Has anyone had any luck straightening them?
2. Has anyone ever welded a piece on the cradle to make it deeper in hopes the loader arms won't jump out?
3. Is it really that important the Main Frame Brackets be perfectly straight?
4. Is there any difference between the dark painted ones vs. the orange painted ones other then the color?
Any suggestions or ideas are needed!
