Just installed a Kubota 3 pt hitch and a Land Pride backblade today.
The BX25 didn't come with a 3pt because it has the backhoe. The 3pt kit was a snap to install. I was concerned how easy it would come off to re-attach the backhoe. I would bet I can remove the BB and 3pt and hook up the BH in 20 minutes. I'm slow and rest a lot.
I am going to replace all the cotter pins with slip pins, or what ever they are called.
I found a piece of 1" ID PVC in the shop. Split it on the table saw so it had about a 3/16" slot. It went on the blade edge with a little help from the rubber hammer.
Not much snow left, but had enough on the sides of the drive to test the blade. Worked perfect. Ran it over gravel and grass. The plastic pipe on the blade edge worked great.
I may have to put an extension on the 3pt ctl lever. I had to reach to lower the blade when turned toward the rear of the tractor.
Bill W. Ohio
Bill W. Ohio
