I have the 64 in LX2980 on my LX3310, very happy with it. I recently unscrewed the bolt on the side of the reduction case to check the gear oil level after running the blower briefly. As I loosened the screw, out came---foam! The foam disappears after a while when not using the blower. I was concerned about water or contaminants in the oil so I drained the reduction case, flushed it with new gear oil, and refilled it to the side plug level per instructions. Ran the blower for a few minutes, loosened the level check bolt, and foam again. At this point I'm pretty sure there are no contaminants present, and no water other than what's present in the air in the box with our humid Pacific NW climate. Since the reduction box is only partially filled with gear oil, I'm wondering if perhaps the foaming after use is inevitable and due to mixing with the air. Have any of you with a LX2980 checked the reduction box oil at the level port after running your blower? I welcome comments, thanks.
(I’m hoping someone with a LX2980 is willing to check their reduction oil after running the blower for a few minutes so I can know whether the foam happens with this model, or do I have a problem with my setup)
