Tires keep deflating
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
Bx1500
I am running the machine fairly hard using front bucket
Front tires keep deflating
Is there a way that I can put tires on it that dont deflate?
2,778
I would clean everything up as best you can then try some of this stuff.
I got some yesterday when I was at the dealer.
All the guys said it was a great product and I have heard good things about it, so I decided to give it a whirl.
I hope it works, cause it ain't cheap.
80 bucks for the gallon......I think the quart was 24'ish.
BAP
Dec 31, 2012
2,742
854
Put tubes in them
4,816
Buy better quality tires. The problem with the OEM front tires that come with the tractor is that the sidewall is insufficient for the amount of weight that your tractor is capable of lifting. I have the same issue with my BX23S. When I get around to replacing them I am going to replace them with over-the-road tires that have better sidewalls and carrying capacity. Some trailers use the same size tires as the front tires on your Kubota. Look for a 6 or 8-ply tire.
4,897
Anyone READ the label ???
Lists all sorts of SLOW SPEED uses THEN specifically says ...'Use only as an emergency fix for light duty high speed tires'.
Hmm...
so... if I can ONLY use for temp fix, fast tires WHY the chart of NHS uses ?????
OK, clean tires and rims really,really well, install tubes, max out air to rating on tire sidewall.
If you decide to stay tubeless, use a good 'rim.bead sealer' and +5PSI air.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,410
1,691
Kalamazoo, MI
Looks to me there's not just a deflated tire, but a completely missing tire!!
3,545
2,001
Looks like a wheelbarrow tire being used on a loader tractor?
Judging by your substitute wheel lug bolts with three different bolt/nut/washer combinations you have an operator problem
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
Tires better suited for FEL and heavy loads would likely fix the problem. Your wheel(s) that have puked tires, I'd imagine they're scarred on the interior lip. They should be cleaned, painted, then sanded to smooth the anomalies. For better bead sealing.
Also, running in slick, muddy, hard-pack-rutted areas has tendency to push/pull on the sidewalls. These areas compound tires getting knocked off their beads.
Maybe you need BeadLock Wheels, they're purpose built.
SDT
multiple and various
Apr 15, 2018
3,250
1,041
SE, IN
View attachment 114615 View attachment 114616
Tubes work.
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
That tire that came off, was "8 ply". Yes, I will look for another wheel/tire combo. Is it possible to put bigger wheels/tires on the fronts?
Somehow the rears have held up. They're pretty thick, I think even a nail going through it would not puncture it.
But yes so far I'll look into:
tubes for the fronts
maybe bigger wheel/tire combos on the front
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
Hmm...
I will be going with the tubes
What i would like to do: get a bigger rim/tires on the front
It's a four lug pattern
Put bigger wheel/tires on the fronts, with tubes
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
hahahaha yes
after trecking through mud day after day looking for the tire inflator, running the extension cord etc
Eventually, get tired of all that and just need to get some work done irregardless of what the tire is doing
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
Yes I think you are correct - pushing/pulling on the side walls while the bucket is carving earth, eventually tears them apart
This machine is mostly intended for lawnmowing, not FEL work
but that being said, it is a mini tank, and only the front tires have given me problems
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
Those are the exact wheel/tires that come with the bx1500
I'll look into putting on it a bigger wheel, bigger tire, and tube
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
Ag front
16x7.5-8
This is the dimension of the front tires
Any ideas on if I can put a bigger wheel and bigger tire? Its 4 lug
MOOTS
MX6000
Jun 27, 2019
1,921
2,201
Canton, Georgia
You can’t just toss bigger tires on there. It will mess with the 4wd operation.
Those look like turf tires, most of them are very thin sidewall. Might look into a set of r4 tread in the correct size. And always be sure to be at max pressure on the tire sidewall when doing FEL work.
joesmith123
L295DT, BX1500
Mar 18, 2023
525
134
earth
You think if I put bigger wheels/tires on the front, it wont work?
