She won't crank over.
jaxs
B1750HST
Jun 22, 2023
733
522
So far the B7100 glow plug indicator has not been mentioned (seems to be a rather frequent problem).
Absolutely, it's very hard to see in the daylight, but if you put your hand over it, it should emit a glow
They say thousands of dollars are spent every day on glow plugs,batteries,pumps,harnesses, injectors and such when the only reason tractor doesn't start is burnt out indicator bulb. 😮
jaxs
B1750HST
Jun 22, 2023
733
522
Looks like poor fella ran for cover last Sunday, hasn't been back.
There's lots of snorting and shooting up these days but huffing is out of style so maybe he thought his tractor doesn't fit in.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
320
418
SE, NM
Well, there was a dogpile about the starting fluid. Depending on his definition of "small squirt" he may not have hurt the engine. He didn't say if it continued to run after the squirt. He said it was blowing black smoke while trying to start. Weird, that's why I asked. The most common glow plug symptom is white smoke while trying to start.
jaxs
B1750HST
Jun 22, 2023
733
522
Considering his definition of start as "crank over" I wouldn't place bets on his definitions.
6869704x4
Jun 29, 2011
320
418
SE, NM
Guy signs up asking for help, gets shamed, doesn't come back. Is that what this place is all about?
I hope he gets his problem sorted out.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
136
136
I read a post a couple of days ago about a tractor that was smoking really bad and would barely run.
Have you checked the air filter?
Always start with the easy things first.
