Bx Tool Box
spanky2380
bx2380
Aug 29, 2023
michiagn
I removed my smv sign since my tractor never leaves my property and installed a tool box in it's location. If I ever need my smv sign I have a magnet installed on it and can attach it to my tool box. Total cost was $40 for everything. 1/4 aluminum plate and stainless steel hardware.
BX23S-1
540
201
No where Special
Wish i could do that to my BX23s. My issue is that a toolbox in that location will get in the way when i use the backhoe.
spanky2380
bx2380
Aug 29, 2023
michiagn
No code has to be inserted here.
Could you get by with a 30 caliber ammo can since it's width is only 3 13/16?
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,185
877
PNW-WA
I suffer from the same brain strain. Location, location, location. My wanting to keep it/them inside the stance of the tractor, has my sensible creativity about out of options.
06B3030
Sep 21, 2015
170
226
MA
Use a couple magnets mounted to the box, and stick it to the ROPs behind the seat. When you want to use the backhoe, simply pull it off.
Magnet Mounts
I use one for an LED light on my ROPs...
06B3030
Sep 21, 2015
170
226
MA
I considered magnets for lighting. Not for the cans. I want a permanent stationary solution.
You're pretty limited space wise with the small BX tractors.
i7win7
Feb 21, 2020
3,379
3,982
Central, IL
won't work on BX##80's, wider loader frame
Works for BX##70
06B3030
Sep 21, 2015
170
226
MA
...any room up front by the grill????
I made a mount for my winch up front.
06B3030
Sep 21, 2015
170
226
MA
06B3030
Sep 21, 2015
170
226
MA
You don't mess around. That mount would withstand moving a tank...lol. Nice work.
😄...yea...I tend to over build a little!
bearskinner
Sep 1, 2014
926
241
N. Idaho
Made a tool box, work station so I can carry water line equipment, chainsaw and tools, fencing supplies etc. It’s on a quick hitch, so I can just flip 2 QD levers and take it off.
Trimley
Jul 25, 2023
1,185
877
PNW-WA
bearskinner
Sep 1, 2014
926
241
N. Idaho
Looks like you can set 5 gallon buckets in there too. Milk crates, maybe as well?
It also has a lid, that works as a hardened work bench. Easy to add onto, or replace parts in expensively
Trimley
Jul 25, 2023
1,185
877
PNW-WA
Shaped edges to boot. The man has a woodshop. I would have done the same. 👍
