I've been dealing with this for a while, and have done some lurking and reading. I've found a thread with a similar issue with a cab l6060, but I haven't quite been able to figure out a solution.
I checked my screen in the water separator, as always, it's nearly perfectly clean with 0 water. Last fall, (I had the same issue) I replaced the fuel filter, fuel pump rd411-51353 from Messicks, bled the air, and bled the air out of the injectors and it ran, but not well. Due to time constraints, I put it up for the winter. I used it off and on for short tasks. A few weeks ago, I started grading our long dirt road and it was back to starving within a half hour.
When going up or down even the slightest hill, the tractor would starve out. Check the temperature on the new kubota RD411-51353 fuel pump; it would be crazy hot.
I thought that was the same issue as in the post I linked above so I set about transferring the fuel out of the fill side; 5 min in, the fuel side was empty, and there wasn't any fuel from the draw side making it back over. So, I don't think it is the check valve. There was almost 0 debris/sediment in the fill side tank. I suppose the check valve could be stuck closed, creating a hard vacuum for the small RD411-51353 pump.
I emptied the water separator with negligible sediment and reinstalled it. It filled quickly, but when bleeding the air out of the filter, the small pump only seemed to deliver fuel when turning the key. The tractor started and died within a few seconds of running. Bled the air out of the filter again, but no fuel moved until I cranked it over.
Maybe I got a bad fuel pump?
Maybe the check valve is stuck?
I get fuel into the water separator without issue; when the tractor starves and dies, the water separator is full of fuel. If there was a sediment problem in the tank or a stuck check valve, wouldn't the separator empty of fuel as the tractor ran out?
So, I put it all to you, WTFBBQ. I am at my wit's end diagnosing this.
Is there a way to check the check valve without having to drop both tanks?
Can I take the steel guard off the 030 Crossover tube and use the cross-over tube to drain the pickup side tank?
Fuel starvation
Hello guys, I have a 17 L6060 hst with a cab, it has 350 hours on it. At random times, I will be running the tractor and all the sudden the engine will begin to surge and clatter, the rpm will drop to almost dead, sit for a minute then come back to where I have it set, sometimes it will just...
www.orangetractortalks.com
