2 Safety Questions
UnEasyRider
L3302 LA 526 loader, Box Scraper, Grappler, Forks, Rotary mower, Big Tool Rack.
Apr 14, 2023
136
68
Florida
Finally received my 3302 today. Have 2 questions.
1) Is it safe to work under your loader if it's up but the loader stick is locked??? Could it still come down???
2) When starting should the tractor be in neutral or in gear or does it not matter??? (It's an HST).
I know...probably more stupid newbe questions but hey...it's my first day on the job!
will721
LX2610, Ford 2n, Ferguson TO20
Jun 6, 2023
179
186
Quad Cities Area
1) Unless its chocked assume the loader can drop at any time. They make hydraulic ram blocks that you can use for that exact purpose.
2) Engine starting doesn't matter what gear in an hst.
UnEasyRider
Apr 14, 2023
136
68
Florida
Thank you(y)
Trustable
l2501HST
Jul 5, 2022
193
128
i would recommend starting it in low/leaving it in low when you shut it off. I’ve had one close call with starting it on high and pressing treadle fully. Thank God i was pointed out the garage door and not on an angle. Has not happened again, I believe that was on the second day of owning it.
nbryan
Jan 3, 2019
1,231
763
Hadashville, Manitoba, Canada
NOT SAFE.
Loader lever locked or not.
Visualize one of the boom hydraulic cylinder lines bursting because of a defect, or further down the road from wear and tear and/or damage. Suddenly nothing is holding the ~1000lb of steel in the air.
OUCH and worse.
Only if necessary, as I've encountered when holding something up there with the loader like dressing a deer, I put a stout log upright under the loader to stop it from being able to fall on me, and set the emerg brake too of course.
Startup question may depend on model tractor, my B2650 starts in all HST ranges, N not needed.
UnEasyRider
Apr 14, 2023
136
68
Florida
What is neutral used for if you start it in gear (low)???
UnEasyRider
Apr 14, 2023
136
68
Florida
NOT SAFE.
OUCH and worse.
I thought it wasn't safe too but just wanted to check with the experts. Thanks for replying!
Trustable
l2501HST
Jul 5, 2022
193
128
Honestly maybe just getting towed? May want to verify that. I’ve literally never used it except when the dealer dropped it off and was showing how the gear selector works. Im sure kubota wants you to start in neutral for personal safety reasons but I don’t think there is any reason you have to.
will721
Jun 6, 2023
179
186
Quad Cities Area
Neutral is for towing, I also prefer to lock in my 4wd in neutral just for zero load. Habit from trucks I suppose.
Just to add to the safety aspect of this post and to my previous comment for anyone that comes across it, never put yourself under any suspended load. That includes under the loader, under a car, under anything hanging from a crane or hoist, unless it is completely locked mechanically. Aka jack stands, hydraulic safety stops, ect. Brakes fail, hydraulics leak down or bypass, ropes break, ect.
rc51stierhoff
3,069
Regarding working under the loader…I am sure there are other options and cheaper ideas, but here is an example of cylinder safety stops. This or something similar to prevent the stored energy from crushing you if working under it would be ounce of prevention IMO.
4,471
4,227
Freewheeling so you can move it without the engine running. You may never need it.
May seem kind of useless but I’ve dealt with a few older dozers that had no neutral in the transmission and when they broke down it was either fix them where they sat, crane them onto a trailer, or pull apart whatever was necessary in the driveline to get the thing rolling. You can’t exactly pull a couple bolts and drop the driveshaft like you can with a road vehicle.
UnEasyRider
Apr 14, 2023
136
68
Florida
Makes a lot of sense...thanks for posting that!
