BonnySlope
BX2380FEL, Add-A-Grapple, Titan 48" Box scraper, 60" Rake, 72" Rear Blade, Flail
Hi, maybe I didn't get this but in Bx manual it says CJ-4 oil is meant for engines with a diesel particulate filter (DPF) and not to use on this tractor. I'm assuming my BX2380. On my Dodge truck I use Delo 400 LE 15w-40 and have a good supply of and was hoping to share. Knowing I don't have an DPF, why do they make the statement. I understand I could just buy Kubota's, like I do for their oem filters and hyd. oil. The post I read by a BX owner called his service manager and, you guested it went with Kubota oil. A lot of the diesel oils today read meets CF, CF-4, CG-4, CH-4 or CJ-4 requirements just to name a few classifications, Shell Rotella T4 which I used in my 5100 am looking at again and well probably go with.
Oil and filter replacement are too cheap for good engine maintenance, and with that statement Shell T4 on its way. It's just that line Kubota draws in the sand.
Just came across this,
Kubota | Lubricant & Grease Maintenance Schedule (kubotausa.com)
