B7100 3pt blead.
nathaniel
B7100 Kabota
Apr 29, 2023
Carguy08
I have a b7100 and I just replaced the o-ring for the 3pt piston and now the 3pt doesn't move I know I have the valve in the right direction. I think I need to blend the cylinder. How would I go about doing that?
4,469
You can't and dont need to bleed anything. Either the new oring is not sealing at all or you are not getting flow from the valve.
nathaniel
B7100 Kabota
Apr 29, 2023
Carguy08
Thank you sir. I believe the o-ring is sealing good. I put a new o-ring under the valve and it is a little thicker than the original one could that be the problem?
4,469
Could not say but I generally advise using the correct size orings.
I would suggest you check to see if you are getting oil delivered into the cylinder.
nathaniel
B7100 Kabota
Apr 29, 2023
Carguy08
I spent a little more time looking for the right size o-ring and replaced the big one with the right one and it works thanks.
