I have a Woodland Mills chipper on the way and I’m wondering how to engage the PTO then dismount to feed the chipper. If I remember correctly, the seat safety switch will kill the engine once the weight comes off.
As you raise your body up, grab hold of the back of the seat and raise it as you get up. Lean it on top of the steering wheel... You don't have to set the brakes. although a good idea but not needed on the HST model. Do you have the manual transmission?...the seat safety switch will kill the engine once the weight comes off.//
My L48 TLB seat safety switch quit working......right after I jumpered it.I have a Woodland Mills chipper on the way and I’m wondering how to engage the PTO then dismount to feed the chipper. If I remember correctly, the seat safety switch will kill the engine once the weight comes off.
Your profile says you have LX3310 and the page you posted is for a "fancy" LX3310... NOT the Standard (economical) L3301 that the OP has.... (Don't worry, it's good information none the less)My 2022 L3301 has a button on the dash just for this....
Oops. Details...Your profile says you have LX3310 and the page you posted is for a "fancy" LX3310... NOT the Standard (economical) L3301 that the OP has.... (Don't worry, it's good information none the less)
