I have an issue with fuel somewhere..It will not start unless you hit it with a small shot of either...there is alot of air going into the water sperator..engine runs great ..strong ,,but from time to time will skip like air is in the system..I have replaced fuel pump and water seperator to no avail..it has the 3 cyl turbo engine in it ..compression is 400+ per cyl..it was doing great and got parked for a couple of months and this is way its been. Even after running it for an hour and turn it off you have to hit it with a shot of either to recrank even hot... Any ideas on what to check next?
