I'm going to remove the hoses going to the cab heater and fix them another time. Do the ports on the supply and return of the cooling system have nipples in them that I can remove to plug them?
This is the page right out of the WSM. Not sure if it's a typo or notMore likely inlbs. 90 inlbs = 7-8 ftlbs
Geez -, I just do “snug.” No way I’d do 90 ft. lbs.This is the page right out of the WSM. Not sure if it's a typo or not
Yes it's a typo!This is the page right out of the WSM. Not sure if it's a typo or not
Here is a pic of the proper tool to tighten your oil drain plug.This is the page right out of the WSM. Not sure if it's a typo or not
No Kubota didn't change, the oil industry did.Got the rad filled and loader back on and had it running yesterday. I checked all connections for leaks and don't see any. I think I'm good to go. Just curious as I used 10 w 30 diesel engine oil from Kubota as per WSM but the dealer said that they see most people use 15w40? Did Kubota switch oil specs at some point?
