yes probably, I dunno why I never thought of thatYou probably have the fitting in the compression kit to check the compression at the glow plugs.
back story: got it for a steal from someone who bought a ranch and it was just sitting thereGreat that its 'sorta running'. What's the back story of this tractor? Is it new to you? Was it sold as having an ok engine? Was the hole in the exhaust manifold there when you got it? Pretty unusual. FYI the starter switch is wired to keep power to the glow plugs while it cranks.
Intake manifold does still have paint on it, let me look again to see if maybe it looks like metal in the pictures i providedCongratulations on getting it running!
I think you should have the injector rebuilt or replaced. I can’t see well in the pictures but some of the bypass fittings look like they are not installed correctly and fell out. That will probably leak diesel fuel on top of the engine.
Also I think the intake manifold should still have paint on it since it doesn’t get hot enough to burn it off. Do you have any idea why it is bare cast iron now? I know that these engines are easy to overheat and crack heads on. But I am not sure if overheating would cause the paint to burn off the intake manifold like the exhaust manifold. Perhaps someone else with more experience will answer this question.
I think the L295 is a thermo siphon system like my L185 with no water pump but I may be wrong about that. If thermo siphon then keeping the radiator and screen in front of radiator is mandatory to keep it cool.
I'm assuming you are making that statement after you saw it and heard it run?Stop take a deep breath.
That engine needs a complete rebuilt period!
Throwing external parts at it all day is not going to make it run any better!
The pictures just look like there is no paint but it could just be a layer of dust or something making it look that way. If you say it has paint then I believe you.Intake manifold does still have paint on it, let me look again to see if maybe it looks like metal in the pictures i provided
L295 does have water pump
Ran it and drove around for 1-2 hoursSmoke is one factor, but sound of it more than anything, it's knocking hard.
Watch the temp really close as you run it.
I did change that manifold from a parts L295, but there is still a gap where it bolts in to mufflerI'm with Wolfman on this - if it continues to run this way it may self-destruct.
Looking closer at your vids and pics, its clear this tractor was repainted - and the top of the cylinder head was missed - it still looks like a 40-yr-old Kubota engine. My guess on the hole in the exhaust manifold is that something hit it from the outside punching a chunk of the cast iron IN not out - maybe still laying in there
Ok, I look into how to do that this procedureI'm with Wolfman on this - if it continues to run this way it may self-destruct.
With the injector work so poorly done in the past, the knocking could be from some small part falling into the a combustion chamber and now banging against the head when the piston comes all the way up. There is near-zero clearance at top dead center. A washer or small metal part in there would get continually hammered into the top of the aluminum piston. Unbolt the head and have a look - hopefully the piston isn't broken.
Unbolt the head and have a look inside. If it continues to be run as-is there's a chance of doing more serious damage - maybe destroying it - a big escalation over what might be possible to correct it now.
Dick B.
If I have to do serious surgery to this degree, I need to have an organized place to do thisThis may be down the road a bit - but if a piston needs to come out, the job starts by taking away the front axle, a necessary step in removing the oil pan for access to the connecting rods. Bottom-end work on many 4wd models takes significant wrenching for access to the connecting rods. If the crank is found to need work too, then separate the block from the transmission. The crank would come out the back end of the block. If you go through all that, you'll qualify for the official "orange wings" medal. Best luck - Dick B
If something got in there the shouldn't, it could be hammered into the soft piston and stay there. But that much noise doesn't usually fix itself - and isn't usually benign. Taking the head off is straight forward - just undo the injector pipes and unbolt it. Might be able to see what's making the racket.If a small part got in there, wouldn't it eventually disintegrate because of heat/pressure/time
Could the piston be broken and it be running fine with plenty of power etc?
