bbxlr8
Hi all - Need advice on my BH77. Not sure what is going on or if I have a real problem or not.
Read all previous threads I could find and none seem to have this issue without a lot of hours etc.
Last Sunday out of the blue the BH boom would not hold and visibly, sagged, losing pressure when running. Did it consistently over the course of 2 hours run. Would operate fine but drooped. If I estimate, it was about an inch every 20 seconds or so. Never any issue before. Oh, $h)# !!
Here is the background:
MON morning I called service @ my dealer where I bought it to ask. Was told it was out of warranty on Friday, but to bring it in and he would try to see what he could do (no promises but fair). I don't have a trailer and $300 transport and they have"weeks" backlog. Looked at uhaul specs w/car ramps a @ 41" min.
Go out to measure the tire track (knowing it wouldn't fit) , pull tractor out and check it again - It showed NO signs of doing so even at low idle or off - left the lock off and came back 30 min later - nothing!!
I saw some had this issue intermittently where they theorized that some particle or contaminant gets caught in the valve and then flushes out...
WTH...is there really a ghost in the BH or just a fluke? Common sense says move on. I used it for another few hours Tuesday and all good. But, I don't want to be stupid if I should get it into the dealer now rather than sticking my head in the sand and have expensive repairs soon after. Have lots of work planned in the next several weeks before Memorial Day.
What do you all think?
- L2501 with 190hrs prob about 60% BH time if I had to guess.
- Did 50hr maint. with full hyd change for my own peace of mind (conservative). Used K filters & fluid.
- Use it pretty hard as I have rocky ground and a few major grading projects over time. To that end, had the BH on/off several times in succession over the last two months using rake & BB.
- Always careful about contamination & cleaning connectors.
- H. Fluid is in the middle of the sight glass.
