My f2560 will run in crank position but wont keep running in run position. I have checked fuel pump solenoid and works in run position, fuel transfer - works clicking, ignition switch works fine ( i replaced all these with working ones from another machine) When I turn key to crank position it runs but when i let off to run it stops. Also when I keep crank turned it runs, but when i let off brake will stop even though I hold crank on. Checked contact on brake switch seems fine. Thought i would run a wire to fuel solenoid but it does click on when key turned to run mode. Getting ready to go under and check for bad connections or shorts in other wires. Any advice or experiences?
