Read the manual a few times but didn’t see it. My 1880 has the lock rear differential option. Have noticed 4 wheel drive is not true all 4 wheels lock all wheels. So, can I engage the differential lock and the 4 wheel drive at the same time? Thanks.
Nice modifications,.... and SWEET boots !Agree with all suggestions and add it is important to keep the lock fully engaged while using. Of the many tractors I’ve owned or operated, Kubota has the worst engagement pedal. Bent round bar with a stout return spring. Keeping it fully engaged while driving a treacherous path a challenge. Often if the ground is slick or muddy my boots are too. We have to use the locking feature more than most on our hillside farm. I made pedals from a little pieces of scrap steel tubing and split shaft collars that help give boot traction and easier to keep fully engaged while using. 9/16” and 5/8” shaft collars.
View attachment 100110 View attachment 100111 View attachment 100112 View attachment 100113
Oddly the bigger one works best on the smaller tractor. Several places in our yards have places you have to engage diff lock to mow.
M5030DT had a wonderful Detroit type auto locking front differential. Locked both when loss of traction but allowed over speed of outside tire in turn. All tractors should be made that way.
My wife gets to model!Nice modifications,.... and SWEET boots !
"Specialtyrepairsandcustommods.com, in NL.,Canada sells a mod. for the diff. pedal also.
Great folks, who make great stuff for our Kubotas!
I must rely on guys like Paul, because I cannot weld!My wife gets to model!
Paul Short definitely makes top shelf attachments and highly recommend. However only for limited models. I have made 4 pedals and vary significantly from model to model. Easy fabrication project with limited tools required. Only a couple of bucks for the shaft collars on Amazon or eBay.
I know if your on pavement not to use the diff lock as that will damage the rear end. Would only use in the winter time when needed.I suggest that you do not use the differential lock while turning. Sometimes you may have to keep the differential lock engaged while turning but keep the turn as shallow as possible and release the lock as soon as you are out of the slop that made you need to engage the lock. Otherwise damage could result. I once blew out a rear axle seal that probably was the result of turning with the differential lock engaged.
" I have owned 4 welders....that I have never used." What causes that? My wife has shoes she's never used!I must rely on guys like Paul, because I cannot weld!
A Miller Thunderbolt. an Everlast E-140MIG, a Hobart Handler 190, and a Miller Matic 250 MIG.
Only have 3 now!
The Miller Matic 250 MIG .... I did try once, ......and sold many years ago.
The Thunderbolt is 30+ years old, and has been used once (will keep it).
The Everlast I- MIG 140e is new, never used, and is listed for sale on Facebook Marketplace.
Sold Lotos LTP 5000D plasma cutter (unused) this week).
The Hobart Handler 190 is new (3 years ago),........ and maybe I will still learn to use it (will keep it).
In my case, I attribute it to good intentions, with no follow through." I have owned 4 welders....that I have never used." What causes that? My wife has shoes she's never used!
This is brilliant. I want one.Agree with all suggestions and add it is important to keep the lock fully engaged while using. Of the many tractors I’ve owned or operated, Kubota has the worst engagement pedal. Bent round bar with a stout return spring. Keeping it fully engaged while driving a treacherous path a challenge. Often if the ground is slick or muddy my boots are too. We have to use the locking feature more than most on our hillside farm. I made pedals from a little pieces of scrap steel tubing and split shaft collars that help give boot traction and easier to keep fully engaged while using. 9/16” and 5/8” shaft collars.
Yepper Wildfire makes some really neat stuff,,, the only problem with what he makes is the shipping costs, getting stuff to the lower 48 is expencive and really in Canada as wellMy wife gets to model!
Thanks for the kind words but was showing how easy it was to improve the pedal function. Kubota doesn’t make it easy as different models require some customization. Sorry I don’t make them to sell.This is brilliant. I want one.
One time I had my Toyota 4runner backed into the garage with the diff lock on after an ice storm and forget about. Couple days later my wife is going into town in the 4runner. Calls me a few minutes later, says that the center console felt "like it was getting hot". I immediately remember, think OH S***!!! Tell her where the button is to disengage (electrically actuated, switch is on the front overhead control panel, NOT intuitive, especially since they went to the trouble of a real 4wd shifter knob). I shuddered to think of what harm it might have done. Still do. But that thing has still been going like a beast for several years since so, I guess no harm no foul.
Anyway sell me one of your pedals.
