My new L2250Dt smoking from engine oil filler & overflow
Pau7220
Aug 1, 2017
785
278
Scranton, PA
We are talking a minute amount of oil (just enough to provide a seal for worn rings), you aren't going to hydraulic a cylinder that way and certainly not going to fire off the engine with all the glow plugs/injectors removed. Compression testing a diesel engine (just like a gas engine) involves disabling the fuel system. The procedure is in any FSM.
In the OP's case....if a careful retest yields the same results as the first, I'd quit right there and start planning on a rebuild/overhaul. But there are good reasons for wet tests and leak down tests of cylinders.
Where exactly did you read that I said the engine would fire off?
I’ll save the sarcastic reply on disabling the fuel system for a later time.
Minute amount of oil? Couple of squirts with an oil can? Then spin it over with the glow plugs out… now you have oil mist in the cylinder… compression gauge back in and spin engine… oil mist in that cylinder fires off with the first rotation.. gauge goes to 600psi or more. Completely inaccurate reading and nothing learned. Maybe there’s one too many squirts of oil, or it fires way before TDC and bends a rod.
As I said, “there’s no need for it”.… And no risk of further damage.
Not my first rodeo….
Another well respected opinion…👇
jhende43
Kubota L2250 & bx1800 & a 1964 CAT road grader(grandpa’s)
Nov 11, 2022
22
Caliente CA
W
Where did you read that I said the engine would fire off?
Minute amount of oil? Couple of squirts with an oil can? Then spin it over with the glow plugs out… now you have oil mist in the cylinder… compression gauge back in and spin engine… oil mist in that cylinder fires off with the first rotation.. gauge goes to 600psi. Completely inaccurate reading and nothing learned. As I said, “there’s no need for it”.… And no risk of further damage.
I will not wet test thank you all for the warning I had the oil can squirt bides in mind personally.
for the repeat compression test
1. Bat charger hooked up for testing
2. Leak check after tests with soap spray
Anything else before re test guys?
Pau7220
Aug 1, 2017
785
278
Scranton, PA
As NIW said, you can pull the rocker cover off and make sure you have a touch of play in each rocker arm when the valves are closed… just to make sure you don’t have a tight one holding a valve open.
jhende43
Nov 11, 2022
22
Caliente CA
Finally pulled the rocker cover off and rocker arms all have slight play as described I turned motor by hand with glow plugs out.
Re compression tested with full battery charge and charger on for test. Compression did go up but still have two cylinders low
275 rear
375 middle
265 front
Soap sprayed each no leaks no bubbles
jhende43
Nov 11, 2022
22
Caliente CA
So after testing I tried to rip into the FEL to detach it went great but got stuck
MANUAL says to disconnect the 3 hoses with quick couplers
Next step is where I’m stuck
After hoses are disconnected then
“reconnect the hose remaining on the front hydraulic block to the out port of the front hydraulic block with quick coupler as shown in the figure.“
PICTURE ATTACHED of figure and instructions
There is no hose remaining it said to disconnect the three quick couplers.. All hoses are now disconnected and hanging freely.
Are my hoses not factory and I SHOULD have another quick couple in middle of a hose to loop the in and out or ?? I hope that makes sense haha
THANKS EVERYONE AS ALWAYS AND HOPE THIS HELPS SOMEONE ELSE ALSO IN THE FUTURE
6,351
You can accomplish the same thing as attaching a hose loop by turning the slotted valve in the middle of the block.
Just turn the slotted valve counter clockwise.
You'll know you got it right if the three point works.
jhende43
Nov 11, 2022
22
Caliente CA
Will do Wolfman my wsm mentioned the spool also and said turn To the “o” mark which I couldn’t find no matter how much I de greased and wiped .
Should I start a new forum for the pending rebuild or continue here what’s proper etiquette lol
Flintknapper
L2350DT
May 3, 2022
1,764
2,216
Deep East Texas
The wet test procedure is called out in many FSM's for certain conditions to help determine if the issue is with the piston rings/cylinder or the head (valves) I'm sure you know.
Obviously you don't over-do the amount of oil deposited. Then the engine is spun over 15-20 times BEFORE you install the pressure gauge. That leaves only a fine coating of oil left on the rings and cylinder walls NOT a 'mist'. Mechanics do this all the time with diesel engines.
It can be argued whether or not it is beneficial...but it is not dangerous if you don't screw it up, which some people can do no matter what.
In the OP's case....i think it is clear at the very least....a re-bore is likely needed, or better...re-sleeve it and overhaul everything else.
6,351
You can do either, which ever you would like.
Flintknapper
L2350DT
May 3, 2022
1,764
2,216
Deep East Texas
Would love to a new/dedicated thread to the rebuild. It would be easy for others to find in the future (using the search function) as it would not be attached and at the end of this one.
Good luck with it.
Flint.
#40Fan
289
165
Didn't we have an engine on here a while back with a blown headgasket that was allowing combustion gases into the crankcase, or was that another forum?
Either way, I'd pull the head first and take a good look at things. If that much compression was leaking past the rings, I'd expect to see a couple torn up cylinder walls.
6,351
Kubota's having a "Blown Head gasket" is mighty rare.
I've never seen one that wasn't installer error, EG. Using a spray on head sealer and / or not properly torqueing the head.
If it did have a "blown head gasket" it would almost certainly not run and it wouldn't be a pressure drop between 2 outside cylinders with the middle cylinder having good pressure. ;)
jhende43
Nov 11, 2022
22
Caliente CA
Can not argue with an answer that specific, pressure drop with middle cylinder having good pressure is exactly what I have.
I will start a new forum for the rebuild AFTER I tear the head off, inspect pistons and sleeves etc etc, and report back here of course with a few mandatory pictures because if you don’t have pictures it didn’t happen haha.
When Taking the head off anything I should look at, into, or out for ??!!
Thanks ALL as always!
Flintknapper
L2350DT
May 3, 2022
1,764
2,216
Deep East Texas
Torque sequence for the head bolts when removing the head is a good idea.
I doubt you'll find anything wrong with your Head Gasket...but inspect it carefully. IF there any damage to the fire rings of the gasket check carefully for any flame cutting on the head or block.
Check for any signs of valves that weren't closing completely and if you find any...for burned valves.
