mcmxi
I have three factory rear remotes on the MX and I've noticed two of them are problematic on start up and one remains problematic. Hydraulic oil level is "perfect" and both the transmission and hydraulic oil filters were changed at 50 hours and clean oil added to top off the system. I currently have 110 hours on the MX and I let the tractor warm up before moving snow. I raise and lower the snow blade a couple of times, and raise and lower the blower a couple of times prior to moving to warm the hydraulic fluid and circulate it through the lines.
I use one remote to rotate the snow blower chute, one to change the deflector angle and the third "float" type remote for the cylinder that tilts the implement. The chute rotation remote works right away, the chute deflector remote doesn't work properly when I first start blowing snow (slow and only works in one direction) but then works fine after a few minutes, and the "float" remote once working won't reliably lock out in float mode (more recent development).
I'm not sure if this is a hydraulic fluid temperature issue or a valve adjustment issue or both. The MX is still covered by the factory warranty and I assume the remotes are covered too. The remote with "float" only recently started having lock out issues, but has been having general operational issues for weeks.
I have some factory literature pertaining to the remotes but will need to see if the remotes are adjustable. If anyone has any ideas as to what might be going on I'd appreciate it. Worst case is a trip to the dealer when the weather is better.
