Can you describe what you are seeing?Well that was very enlightening
You have Both a engine and Rear end / HST issue going on!
You need a competent mechanic to work on it!
The engine has all sorts of issues that I can hear and see.
Tank has been cleaned, fuel pressure checked at lift pump, injection pump pulled and recalibrated, injectors replaced, brand new turbo.So sorry to hear that you are having these problems!! Sounds like a fueling issue of some sort either from the tank, lift pump or injection pump, possibly even governor?? And then there is the hydrostatic pump, not even sure where to start there??
Hope you manage to find someone competent to work on this one!! These tractors are not even all that complicated, pre tier 4..
Please quit running it, it's got problems and running it is just possibly going to make them worse!
They got it wrong!It literally just came back from the engine building shop.
If it blows, it blows, I honestly don't care at this point. 12k down the tubes. I got a call yesterday from a fella that told me to drive it and to see what hydro line gets hot.They got it wrong!
I'm guessing you are in Idaho? Just curious, what is your background?You pay the shipping and I'll fix it for free!
It's sad you have been taken on a money sucking ride with this tractor.
A ton of tractor / equipment repairs over many years.I'm guessing you are in Idaho? Just curious, what is your background?
Maybe I will see if my buddies trucking company can drop it off if I can't get this solved.If you want to know more, Just PM me and I should be able to give you any details you might need.
