And just to be clear....the L47 is the Porsche?A L47TBL is in a completely different class than a L4701 they really are not comparable at all.
Kind of like trying to compare an old VW BUG engine and Porsche engine, while they are basically the same blocks the rest varied greatly!
Kind of like trying to comparing a Opal GT and a Corvette!
Kind of like comparing the Falcon Heavy Rocket and an Atlas rocket!
You get the point!
They're not chalk and cheese. Same basic frame. But yes, the L47 is a dedicated TLB, so it's built to run a backhoe. If backhoe is important to you, and you can get an L47 for same or less than the L4701, that's a good idea. And it's otherwise quite similar to the L4701 - the FEL doesn't come off easily I think (so if you want to run without a loader it's no good for that), but I think the backhoe does come off and you can fit a 3ph (you might have to buy the kit). So for 3ph stuff it does everything the L4701 does. And it does loader and backhoe stuff better.
