I have a B7200 non-hydrostatic. As I understand how this sort of transmission operates I can/should not change gears while on a slope; I would need to brake to not roll down the hill but can't move after changing gear with the brake depressed.
Yesterday I attempted a very simple project on one of the softer slopes at my property. The goal was to come from the garage you can see in the distance, come up the sight slope, then collect some logs, take the logs further up the slope (which flattens just beyond the photo).
When I got up to the logs I had to be mostly perpendicular to the slope in order to be in a position to move between 1st and reverse. This made it so I wouldn't roll back down the slope but forced be in a bit of a tight spot between my house and the retaining wall. And this is the main issue - not being able to change gears on the slope put me in a tight spot. It also required me to go all the way back down the hill when coming back.
I'm sure drivers with more experience could maneuver more comfortably but for a newbie this was a challenge.
I did a few loads but as you can see I didn't finish. This wasn't the right tool for the job for my skill level. Would I have better luck with a hydrostatic transmission? Would that mean I could change gears on a slope so that I would have been able to come at the logs from a sloped but better angle?
