Head Scratcher??
aaluck
Oct 9, 2019
946
771
Snowdoun, AL
My left rear tire is giving me fits. Every couple of months it will lose air for several days (sometimes just a day) and then just stop. Example: Last week it was low so I filled it, next day low again (and I mean visibly low), this went on for about 4 days. Filled it on the 4th day and now its holding air perfectly again--for now.
I have used several gallons of soapy water and sprayed the tire to near clean condition trying to find this "leak".
Has anyone else experienced this and what did you do to find the leak?
2,551
I had that with my BX25D ........
and I have had that with car/truck tires.
IF the "leak" is pointed down, it leaks more - if the leak is up off the ground it leaks less. OR something like that !
Check the valve to - soap around that and you may find it leaks.
PaulR
Aug 3, 2020
579
459
Hadley, MA
I swear by Green Slime. I think I have it in just about everything in my garage that has an inflatable tire.
2,551
I too use a lot of the green slime .......... have used almost 2 gallons over the last 3 years!!!!!
PaulR
Aug 3, 2020
579
459
Hadley, MA
Yes, no sense in buying it unless you buy the gallon size jug with the pump top. I'm on my second gallon too, lol. I make notes or mark what tires I put it in so as not to surprise the tire guy when the time comes. Tire guy years ago told me he appreciated that with the old school aerosol fix a flat.
rc51stierhoff
3,093
Is the tire loaded? If not too much trouble to remove you can always pull it and place in a baby pool / trough / or larger body of water or something to chase the leak…if it leaks it out in a day I would think you should be able to hear it maybe. Are you sure it’s not a sticky valve core? Just some thoughts if not tried them or something similar. Good luck.
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
611
808
Ontario, Canada
After owning my tractor for a year, suddenly found front tire flat. Jumped to conclusio to early and was ticked I picked up something in the tire. Couldn’t find anything. Then I find this. I know 100 percent operating the tractor on my grassy property I did not do it. Actually found three bends. Two on the inside, and a minor one on the outside.
Dealer did warranty for me. Only thing I could think of was the position the tire came to rest when park
4,913
maybe do this...
break the bead , scuff up the powder coat on the rim,add 'bead sealer',
do it again for the other side of the rim/bead.
then blow up the tire, leave 'over pressure' for an hour, then reduce to normal pressure
armylifer
Mar 26, 2013
2,051
784
Thurston County, WA
It sounds like a rim leak to me. Doing as GreensvilleJay mentioned will probably be the ticket. There is also a chance that the valve core is bunged up and needs replacement, as mentioned by
rc51stierhoff.
