I inherited a 1980s era L275 tractor, which mu Stepdad had bought 'Used'. It came with a mounted, Kubota Front End Loader, which appears to have have ZERO identifying marks or labels. Is there some way to identify what model this unit is?
That stamping (on mine) is on the top of one of the lift arms of the front loader. Fairly small, would be easy to miss if you were not looking for it or if heavily painted.It is a stock Kubota unit (Forgot about the Kubota decal, on the right side Main boom rail). The Hyd Fluid feed & return lines are both tied to the tractor's internal Hyd pump. I'll try the Kubota site again, but I sure wish that I knew which portion of the assembly that Flintnapper's pic was looking at. I'll go give it yet another visual inspection. Thanks!
Second the L1200. you can find the manual for it online, just search "kubota L1200 loader" and the pdf is one of the first things that pops up. (I'd attach it here but it says the file is too large)Model 1200
