Captain13
This is your 3 pin, I believe. You need the male end of this to make an extension. John Deere should have both connectors that you need to make extensions. Your bailer should be compatible with any tractor and JD usually Carrie’s these or you can probably order what you need from Jensales in the link or anyone else sells ag equipment. Actually, any tractor shop that sells bailers should have or be able to get these (except Kubota) because they are probably all (John Deere, Case, MF, etc) compatible.
John Deere 568 Round Baler Auxiliary Power Connector Kit, 3 Pin
www.jensales.com
