I have a l5740 that runs one bar past the middle whenever its under load or working. I have
flushed the coolant and replaced with new green coolant 50/50 plus a coolant additive,
used an air compressor to thoroughly clean radiator fins, then wash the radiator with water hose. I have also, tightened the fan belt. Operating temperature outside is currently 95 degrees and I'm running rotella T6 engine oil. Temp sensor does return to the middle after idling for a few minutes. Any ideas?
