The bucket on my 2680 is extremely touchy. Seem like it is full go or stop. Other tractors I have had you could operate the bucket much more smoothly very easy. Is there anything you can do to the hydraulic valve to get a smoother operation?
The BX models all have a pretty small hydraulic pump. At full operating rpm you get maximum flow but the output drops off at slower engine speed. If things are too jumpy, try slowing down the engine before looking for more complex solutions.
The metering performance of spools in DCVs is primarily a function of gland overlap and edge design. You typically pay more for valves that provide better control of metering but it often comes at the cost of increased spool leakage. Somebody in engineering/purchasing made a cost/benefit decision and AFAIK short of replacing the valve with a better one you are stuck with it.But Scotty, I need more POWER!
Seriously, if I have to slow it down to get it to work decently, that's a design flaw. I would love to find a way to adjust it.
The way to adjust it is with the throttle. You don't need to operate at max rpm all the time. You don't want to putt-putt around at ldle either. The best engine speed varies from task to task.But Scotty, I need more POWER!
A nice, new, or used L47 TLB would solve your issues.When I'm trying to dig in hard soil and deal with roots, I need everything it has to offer. Reaching back to adjust the throttle for every swing of the backhoe is not exactly a practical solution.
Combining boom and swing motions makes it more manageable.
