I bought my 2022 2501 in March and hoping this fixes my starting issue. I have the front bucket buried in a pile of rock on a slight hillside and need power to get it out. I will let everyone know if this was the problem:
I did watch the video as I have a L2501 HST also and like to learn the potential trouble spots, thanks for posting!I bought my 2022 2501 in March and hoping this fixes my starting issue. I have the front bucket buried in a pile of rock on a slight hillside and need power to get it out. I will let everyone know if this was the problem:
This youtube video was very accurate for my problem, which was that it clicks as normal when I turn the key, the lights stay bright, but the engine does not turnover, and the solution in the video worked!I bought my 2022 2501 in March and hoping this fixes my starting issue. I have the front bucket buried in a pile of rock on a slight hillside and need power to get it out. I will let everyone know if this was the problem:
"hope you solve your issue quickly". Thanks Henro. The video did such a good job of explaining the same issue that I had, and I wanted to keep it simple here for others who are in a pinch. You know? Quick reference and keep it simple before we over complicate the problem.Did not watch the video. But assume you mean the starter does not turn the engine, so the engine obviously can not start.
If you explain your issue without expecting people to watch a video and try to figure out what is going on with your tractor, it might get you some good advice...
Just a suggestion...hope you solve your issue quickly.
Actually, you might just be promoting the video to begin with...if so, thumbs down on that...
"I believe that netsomnia is not needing or wanting to promote the video, its a older video and doubt it is even his, but just wanted to pass on his experience with his tractor and potential fix. "I did watch the video as I have a L2501 HST also and like to learn the potential trouble spots, thanks for posting!
Note; I believe that netsomnia is not needing or wanting to promote the video, its a older video and doubt it is even his, but just wanted to pass on his experience with his tractor and potential fix.
Thanks for the details. I appreciate it.Seems like a pretty bad video. The thread I started has more info along with the fix for me. I can't think of any reason why you'd need to buy another part.
L2501 HST Safety Adjustment?
My L2501 is sometimes hard to get to start. I know it’s the HST Safety switch. Some people have posted that theirs was out of adjustments on other Ls. I took a good look and couldn’t seem to find an adjustment. I sprayed down the switch and it started. Shortly after it refused to start, so...www.orangetractortalks.com
