Hi guys
This is my first post and I’m located in France.
I have a couple of Kubotas one of which is an old b7001. A great little workhorse which I bought with the house 16 years ago.
it was starting to give me trouble to the point I could not disengage the gears and could only stop by decompressing the engine.
Finally took the plunge and split it apart.
found that the spigot bearing had failed and was chewed up to the point it was jammed up giving direct drive from the crank to the input shaft.
has any body experienced this problem before and what caused it to happen.
all the other components were in good shape.
Does anyone no the kubota part number as I need to order new one.
thanks in advance
thanks in advance
