Hello,
I have a 2014 SVL75–2 in limp mode with e9214 displayed.
The error code is stating DPF regeneration cycle occurs too often.
I took this machine to the dealer and had them diagnose it originally. They remove the DPF filter and had it cleaned and suggested I replace the fuel injectors. The quote from them was nearly $8000.
I passed on replacing the injectors and about 10 hours of operation time following, the e9214 code came back on.
Since then, I tore the machine down myself, had the DPF filter professionally cleaned again and replaced the fuel injectors.
The machine is currently starting and idling as it should but is still in limp mode because of the error code.
Any suggestions on how to clear the code? I know it’s a sequence similar to my tractor but I’m unable to find any information on it.
I also purchased the workshop manual for torque specs primarily but cannot find any information about clearing codes in there.
