Which relay would it be the fuel relay or starter relay? How do I find the part online?That’s a relay…
Thanks for the help. I appreciate it. Would the glow plug relay cause the tractor to start and then die 10 or 20 minute later and then not start again for 2 to 4 hrsWhich relay would it be the fuel relay or starter relay? How do I find the part online?
check my edit and maybe this link will workWhich relay would it be the fuel relay or starter relay? How do I find the part online?
I would say no, but I have no idea if the relay I posted is in fact the glow plug relay or how the tractor is wiredThanks for the help. I appreciate it. Would the glow plug relay cause the tractor to start and then die 10 or 20 minute later and then not start again for 2 to 4 hrs
I agree this 'sounds' like a fuel-delivery issue.start and then die 10 or 20 minute later and then not start again for 2 to 4 hrs
Nope. Not a possibility.Would the glow plug relay cause the tractor to start and then die 10 or 20 minute later and then not start again for 2 to 4 hrs
I know it is bad because there is a burned out hole on one sideI may have missed something... exactly WHY do you feel the relay in post #1 photo is 'bad' ?
The neighbor took it off and said it was the fuel solenoid relay. I wasn't down there my Son was and he is on vacation right now. I just can't seem to find the part online anywhere. I called a Kubota dealer and told them that it was the fuel relay and they ordered the part and had it sent to our house. When we got it today it definately isn't what is in the picture so now I am trying to find the part myself so I can order it.Nope. Not a possibility.
But then, we still need to determine if that is the GP relay or the fuel solenoid relay.
Can you post a pic of where you found it?
And those three applications are?T1060-33720 relay is used for 3 different applications
Kubota MX5100DT (Dual Traction 4wd) Parts Diagrams
Kubota Parts Catalog Lookup. Buy Kubota Parts Online & Save!www.messicks.com
There are 3 T1060-33720 relays used, but the one that @Fordtech86 mentioned was T1060-33710, which is the glow plug relay and seems to look more like the relay in OP's picture. But all this guesswork is unecessary if OP provides a picture of where the relay was located.ejb11235
Without the aid of a MX5100 tech manual I don't know the answer. if the relay for GP that Fordtech mentioned isn't the correct relay then there's 3 of the same relays shown SO 1 of those relay's has a good possibility of being the correct relay
