Black Oil, Due To EGR system?
Dieseldonato
Mar 15, 2022
728
439
Pa
Oh I don't advocate it as a routine maintenance step. I've done it once or twice just out of curiosity.
Is curiosity a good reason? I've wasted good money on dumber things in the past. <lol>
True, I have as well. Can't argue that point.
3,316
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
He has an M59 if I recall
he pulled my response to Henro who stated
Perhaps as a test I should disable my EGR tubing, and open it to the atmosphere and see what happens. Older tractor without any high tech stuff on it, so I bet I could if I wanted to...but laziness will prevent me I fear...LOL
I was just trying to help Henro, because the title and his posts were kind of confusing a bit.
2,969
I appreciate that!
I did mess up in the post title, and a bit in other posts as well, as nothing related to either the EGR or PCV circuits makes any sense regarding making the oil black...
Now maybe if an exhaust valve guide was leaking exhaust gases into the valve cover, this might theoretically help to darken the oil, as these gases would find there way past oil as they travel along the way into the PCV path...
In reality, is it fair to assume that black oil is the result of blow by exclusively?
If one engine has slower darkening of the oil than another, after the same period of use, is it likely that the engine with cleaner oil has piston rings that seal better than those in the other engine?
Other than blow by past the piston rings, is there any other reason that might cause engine oil to darken?
Dieseldonato
Mar 15, 2022
728
439
Pa
You also need to remember part of the oil rings job is to apply and scrape oil off the cylinder wall, this oil is in the combustion chamber during a burn event. A burn event is a much longer affair in a diesel then a gas engine. So it's not just "blow by" exclusively. Contributing to the oil color. The tighter engines will show less of it.
Worn valve guides typically present as an oil loss issue not going to make the oil much darker from the minimal amount that gets back past them.
2,969
Appreciate the insight. Always trying to learn more as time goes by...
