I keep getting hydraulic oil in my engine. i have replaced the seal in the hydraulic pump several times but it keeps happnening. what could be causing this? Pressure too High? how do I correct it? Thanks for any help.
If you have replaced the seal multiple times and it is stil leaking sounds your pump needs more than a seal. I would guess worn seal area on the shaft and/or possibly worn bushings that allow the shaft to wobble taking the seal out.
