250 hours and will start and run then slowly quit. Weird but if it sits for a while, 1 hour, it will run longer before quittin. An immediate restart will have an immediate stalling after starting.
Good fuel flow to filter and clean filter. Clean aair filter and good suction at air filter when runnin.
Thank you
Oh, and yes I did bleed the fuel system using the valve on the fuel pump. Several times.
Thank you
