G4200 HST Slow Up Incline
kajun
M4700 ,G4200
Mar 28, 2017
42
St Francisville , La 70775
Folks:
This 30 year plus machine is slow on an incline of 10 to 20°. Hardly pulls at all .
It is difficult to see the transmission fluid. I have measured it multiple times today with the fluid cold and it seems to be full. Have any of you thoughts on what could be the problem. It developed at the end of the mowing season last year. Unit seems to work correctly on level ground. I can find no obvious leaks . Fluid is clear and it is SUDT2 . Obliged for any guidance.
2,923
1,385
Folks:
It is either the filter or an internal hydrostat issue. That hydrostat is manufactured by Eaton, Kubota does not offer parts for it, they must be gotten from an Eaton dealer.
avvidclif
BX2230 L285
May 12, 2020
23
Mabank, Tx
Just thinking. If the pump is at the motor and the reservoir is the tranny. Is there a seal from tranny to rear end housing the could be leaking/ Could cause the pump to run low when going uphill. Worth exactly what you paid for it!
2,923
1,385
The pump and motor are in the reservoir, submerged in oil.
kajun
M4700 ,G4200
Mar 28, 2017
42
Thanks ,whitetiger ,BruceP and avviddclif. All very helpful.
This machine is new to me ; coming up on its 3d anniversary with me. I estimate the thing had fewer than 1000 hours on it when I bought it. When I changed the fluids the first time I was surprised how perfectly clean the hydraulic fluid was . When I pulled the HST filter screen to clean [ as recommended ] , it too was perfectly clean .It appears that the machine was well maintained .
You have been very helpful . If changing filter ,fluid and cleaning screen fail to help , the linked Eaton manual will be of great help [ to my mechanic ] . That repair is way above my pay grade .
Deeply obliged .
Torinodan
T1600, G4200, G5200, Ford 2810, 1974 Wheel Horse C100
Oct 14, 2021
199
94
Fayetteville GA
When you replaced the fluids and filter did you raise the rear end and let it "slowly" rotate forward and reverse to get the air out of filter and pump? Ot can be time consuming on this model to get it right.
The pump is mounted high and on the front of the rear axle direct driven from the engine. You can fill the filter before you install it too to let it soak up fluid so this process dosnt take too long.
kajun
M4700 ,G4200
Mar 28, 2017
42
kajun
M4700 ,G4200
Mar 28, 2017
42
Thanks Torinodan. No , I didn't know about that requirement.
I changed the filter and replaced the fluid on Saturday . I let it warm up slowly as the Op Manual suggests .
This time I used TSC Traveller Premium Hydraulic fluid. I could tell it was more viscous than the SUDT that I took out . [ SUDT didn't exist when this tractor was manufactured. ] After the fluid change and after very heavily working the tractor for about 45 minutes , the poor pulling seems to either have been cured or greatly diminished . So , either whitetiger was right about a filter blockage or the more viscous fluid is a better fit for this old machine. I like to be optimistic.:)
Obliged to you and all the other posters.
