Hi folks. First time tractor buyer here in PA with another variation on the B2601/LX2610SU/L2501 question. I’ve searched for input on this topic and didn’t have much luck. I have about 25 acres of mostly flat ground - 6 acres that I mow with a zero turn, 6 acres that I need to brush hog and the rest wooded. The things that I want to do with a tractor are move mulch/wood chips a few times a year around the yard, brush hog 1-2 times a year, move firewood and maintain trails in my woods and around my property, maintain a stone driveway and move snow. The challenge is I have wet soil and soft ground. It’s wet or soggy a lot of the year except when things are frozen in the winter (even with normal freezing the ground is wet a few inches under the top layer so it needs to be a hard freeze) or when it’s mid-summer and we haven’t had a lot of rain. I like the L2501 due to simplicity and power for its size, but I have concerns about the weight and tearing up my yard so also considering a lighter tractor. I believe the B2601, LX2610SU and the L2501 will all meet my needs. For comparison, we get tractor help 2-3 times a year from someone who has a JD1025R with R4 tires – sometimes with a backhoe on. We’ve only had rutting problems once and that was with multiple passes in the same area and the underlying ground was soggy. That tractor with a FEL is similar in weight to the B2601, but the backhoe adds another 600 lbs.
So, based on experience with wet/soggy soil issues, do you think the L2501 is too heavy and I should go with something lighter?
Thanks
Thanks
