Having a fuel issue on my L2950. I’m pretty sure I have a low flow issue guessing a partially clogged line. Main question, if I remove the filter and bowl then open the fuel cock valve, should I be getting the full weight of the fuel’s worth of flow or just a trickle? I think my problem is above the filter.
When turned off and sits for a few minutes, she starts and runs great. But after a minute or two bogs down and eventually dies. The flow seems low when filter is removes and valve is open but I don’t remember seeing how fast it is supposed to flow before the filter bowl.
Thank you!
Thank you!
