Quick disconnect coupling not releasing
Wolfbay farm
M105
Sep 15, 2020
Chipley Florida
The rear grapple has 2 quick disconnect hydraulic lines to my m105 Kubota. It’s been on for a while and I can only get one off. I’ve waited 3 days and still can’t get the other one to release. Any tips on how to remove it?
4,913
normally you 'cycle' the valve a few times, with engine OFF, to release the pressure buildup,preferably leaving the 'item' in mid position(not fully open or closed)
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
635
494
E.
if not visually damaged:
- try first releasing pressure in the line.
- If still no go then it needs a good clean, flush fitting with lots of cleaner
6,399
Reconnect the line that's off and follow Greensvillejay's suggestion.
3,681
When all else fails...
with tractor not running, crack open the line on the offending connection (typically at the line to fitting connection) to relieve the pressure. See if that will enable to disconnect the fitting.
Caution- wear gloves/glasses while doing so, or cover the connection and wrenches with a rag before you break it loose.
