I'm looking to install a block heater in my L245DT. The ones I've seen online go into a freeze plug hole, but unfortunately, all the instructions I've found assume that the plug is removable with an allen wrench. What I have looks like a pressed in cap. You can see it here, looking at the left side of the engine just in front of the starter. (that orange wire coming in from the left attaches to the battery to hook up a trickle charger, in case you were wondering)
Is this in fact the freeze plug hole, and if so, how do I remove the cap? If it's threaded, then I should be able to unscrew it by tapping the edge with a hammer and cold chisel. If it's not, then I shouldn't be thinking of putting a block heater there, yes?
Thanks in advance,
Tom
Thanks in advance,
Tom
