So I got the old Kubota out today and after started, let it run for about 20 minutes to get the hydraulic moving. Used it yesterday and bout 2 hours this afternoon to plow snow. Near the end of of use the blade wouldn't lift/turn anymore and neither would the rear lift. I didn't find any leaks on the lines, cant get under it right now. However I did notice that the fluid had backflowed out the gearshift (this tractor has a shared transmission/hydro system). I'm a bit at a loss unless it's the pump. Is it possible for the fluid to freeze while it's in use? (we're not talking cold, it was 4 over night but in the 30s while I was using it).
I did drain and replace all the fluids this fall to try and be preventative of such situations.
