Greased the FEL today...
FreezinGator
BX1500 LA181 FEL 48MMM Back blade
Jul 10, 2020
58
Upstate NY
I really need to remember to grease the tractor on warmer days or at least put the grease gun on the mantle over the woodstove before I use it on cold days. I got it done but I had to break out the old lever action gun - it sure is easier in warm weather...
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Titan Forks, Caryall, 5' Tiller
Oct 26, 2019
214
376
Moseley, VA
I have the Ryobi and agree they are hard to beat. Especially for the bearings that take more than a couple of pumps of grease like the ones on my boat trailer where the design pushes out the old grease out. Sweet!
dieselbob69
Kubota BX2380 (previously a BX1870 and GR2100)...
Jan 2, 2022
159
61
WNY
I got myself one of these a few days ago😁😁😁… was walking around Tractor Supply, and there it was. They had a kit a few months ago, but it was either $298.99 or $319.99, I set it back on shelf in disappointment, wasn’t going to pay that much, and I didn’t see it next time I went in. When I saw it on clearance a couple days ago, it was going home with me👍….
Mossy dell
B2601 (2021) JD970 (1998) B2100 (1991) B6100E (1988)
Jul 20, 2020
274
125
sw VA
I've been thinking the same thing. I've put at least 6 hrs on the loader so far this week dealing with snow. I have a Lube Shuttle and like it, especially with the LocknLube tip.
By the way, I grew up in Satellite Beach, Florida, and am freezing too! I dislike cold and take winter too personally. Not sure how much that's because I grew up where I did or the influence of my father, probably both. He grew up in Michigan and hated cold. Four of his kids including me were born in southern California, one in Georgia, and one in Florida.
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
Just be cautious with the powered ones. They are great for pins and bushings. If your greasing a joint with a seal pump a little and wait. The powered ones are so quick you can easily pump too much. The one benefit to the manual ones is you have better control, and less mess. To me it seems to be the quickness that blows the seals. The grease packs in too fast to move around gaps. With all that said I love mine, just know how to use it.
forky
L2501 HST 4X4 8N
Feb 23, 2021
266
273
Wisconsin
My neighbor just bought the Makita grease gun. He has everything Makita and wanted to add it to his tools ..... he gave me his Lincoln grease gun with case and charger....I haven't tried it yet....any Lincoln lovers or haters out there?
dieselbob69
Jan 2, 2022
159
61
WNY
I'd prefer to gift myself a heated and insulated barn to park in.
I'd like that, but my backyard floods. I plan on getting some fill so I can at least get a bigger shed, just need to rent a small dump truck so I can manuever where I need to put it...
Tom Cat
BX25 with mower and back hoe
Jan 17, 2022
I bought the DeWalt 20 volt Max grease gun a couple of years ago and I would never go back to a hand pumper grease gun. I not only use it on on my BX25 but also my cars and some railroad equipment. I am 73 and this battery powered grease gun makes my life so much easier when it comes to lubing my equipment. Worth every penny I spent on it. I have never blown a seal, knock on wood. Just don't try to force too much grease into it.
3,316
I have a half-dozen manual lever guns because they each have a different type of grease (which should never be mixed, IMO)…. and so the economics drive my decision and laughter at those of you lazy guys 🤣who complicate your support-missions with tools that have ridiculously expensive proprietary batteries, and become maintenance issues in their own right. :sneaky:
(Just givin’ ya a “jab” in fun) ;)
SinNH
L3430 JD 870 Volvo EC35
Sep 26, 2020
60
NH
Minus 4* F here in NH as I type. Simple fix, I keep my grease guns and a couple spare tubes in the cellar of my house near the boiler during the winter.
BAP
Dec 31, 2012
2,742
854
Another good tip, don’t grease your machine before you use it, grease it after you use it. Grease will flow in better because the old grease is more flexible and warmer from use and you will end up with a better grease job.
3,316
That may work for an oil-change… but for greasing…. I don’t buy it. If a machine needs lubrication to avoid wear-and-tear then it needs it up-front not afterwards. (just the way I think about foreplay.) :p
Bmyers
May 27, 2019
3,293
3,849
Southern Illinois
I have the DeWalt 20v grease gun and it makes quick work of the greasing. The addition of the Lock-n-Lube on it, can't ask for a much simpler or easier setup.
BAP
Dec 31, 2012
2,742
854
Well, you don’t know everything even though you like to claim you do. By the way, if you actually thought about it instead of spouting off to hear yourself, greasing after you use it, is before you use it the next time. Try greasing a machine at -20f that has sat overnight and then try greasing it after it has been run for a while. Huge difference in how well it takes grease. Also when everything is warmed up from working, you will push out more of the contaminates that have worked their way in during use.
