Does anyone else have this issue? I live on pretty steep terrain (one of the reasons I went with a bx23s instead of a B series). My tractor will run fine but sputter and stall out (sometimes) with the tank at about 1/2 way (+/- some). Usually it's on steep terrain, but also happened the other day on flat ground. The fix for it is removing the fuel line from the engine side of the fuel pump, turning on the ignition, fuel will pump out great, hook line back up and run start the tractor. Obviously it seems like it's going into vapor lock so I pulled apart the vent in the fuel cap. This seemed to help for a while, but I'm also not sure that I actually ran it down below 1/2 tank. I'm working in snowy/icy conditions so there's always a possibility of the vent getting clogged again (I just cleaned it out again). I've also tried loosening/removing the fuel cap when this is happening (to no effect). To get the tractor started again, I have to remove the fuel line and then it'll run fine for an hour or so. Anyone else having this issue? It's kind of annoying having to keep the tractor topped off all the time so that it won't stall at an inopportune moment.
