ZD1211w/ no electrical power - just disappeared
Safetyman
ZD1211 Zero Turn
Jan 15, 2022
Central IL
Hello ~ In Central IL my zero Turn ZD1211 is in a nice barn no heat. & trickle charger hooked up to the battery. I went to start it to just move it around a bit. Cranked for a bit, then all power went dead. Figured I blew a fuse. I just checked the fuses under the seat and all seem fine. Still now power tho... where should I look next?
2,919
1,380
You will also have a large fuse within a few inches of the starter, check it. Clean your battery cable ends also.
4,899
Use a multimeter, set on low ohms and put probes on the fuses lugs.
If it reads 0, fuse is good, if it read same as leads not connected to anything( usually 1---) ,it's bad
Nicfin36
Jun 19, 2019
1,016
466
Decatur, AL
Not to be a smart aleck, but have you confirmed that the battery didn't completely crap out on you?
Safetyman
ZD1211 Zero Turn
Jan 15, 2022
Central IL
haha, no offense taken & good point. The battery is a little over a year old and even with a charger on it, no lights/power/nothing when the key is turned. I haven't made it out to replace that fuse yet so it's still dead, but it's winter... other priorities each day. But I'll try to replace this fuse and see if that helps. If not.. I'm out of ideas
07wingnut
254
97
Clearwater, BC, CA
Connect a voltmeter between the negative battery post and a good ground on the frame. Then turn on the key, and there should be no voltage reading on the meter. If there is, check your ground cable connection the the battery negative, and to the frame at the other end. If there is, you need to disassemble the cable from both ends and clean and retighten everything.
AFreddyP
ZD28, ZD1211, M5400 Narrow
Mar 12, 2023
Hendersonville, NC
Hi guys, was this ever resolved? We are having the same exact issue with our 1211. Here's what we've done so far:
1. Load Tested Battery - Good.
2. Disconnected and cleaned the battery cable connections (at battery and at frame for ground, at battery and starter for positive)
3. Checked 50A fuse at starter (with Ohmmeter) - good.
4. Checked all fuses under the seat - good.
5. Checked to ensure continuity at each of the switch positions (on, glow plug, start) with ohmmeter - good.
6. Checked to see if voltage was present at the switch in all positions - good.
Not sure what else to do, looking for some advice on next steps from this awesome community
Thanks,
Andrew
AFreddyP
Mar 12, 2023
Hendersonville, NC
Closing the loop on this one for any future reference of the group. The problem was the positive battery cable terminal had been crimped around the rubber insulation rather than the conductor. While some contact was made, it wasn’t enough to power the mower. Corrected it and all good now.
