kubotasam
[QUOTE="TheOldHokie, post: 518135, member: 46622"
The only position that is using cylinder regeneration is position 3 which is "fast dump". When you go past that to position 4 you have normal speed cylinder/motor control. With the 3 position valve your only have regenerative dump which will not work with a motor.
[/QUOTE]
I made my 3 position regeration only valve work. See post 34 above.
[/QUOTE]
