jyoutz
I’m not very savvy with electrical wiring for 12 volt electrical systems. I’m installing 2 LED lights on my MX6000 open station (with canopy). I understand that install because it has a wiring kit with relay, switch, and battery connectors. I’d also like to install a USB port so I can keep my phone charged to stream radio stations to my Bluetooth headphones. I’m thinking that a battery connection wouldn’t be a good idea because the port would be hot all the time (would that trickle drain my battery over time?) Should I instead tie the USB port to my ignition switch, so it’s only hot when the tractor is running? If so, how and where should I do this? Or would a fused battery connector be ok for the port to be hot all the time? As I said, I’m not too savvy about this.
