Bx2230d.
I start the tractor with the hi/low range lever in the neutral position.
It will move while in the neutral position. (it's in gear without moving the range selection lever out of the neutral position)
If I fail to put it in low or high range and head down a slope it'll pop out of gear and start freewheeling.
Also, the hi/low range selector is not positioned correctly. i.e. does not line up with the hi/low/neutral markings.
I looked at all the linkages and don't see any way to adjust it.
Any help or suggestions would be appreciated.
Thanks
Thanks
