I know this is a long shot, but anyone recognize what this washer could be off of? One side is lined with rubber. Found it on the floor after backing the B2650 out of a building. I don't know for sure if it's from the B2650, but it seems likely.
No cab, but that's an interesting idea. I just went through Messick's site that way for the tractor and loader, no dice. Can't find their parts diagrams for the backhoe or mower.Do you have a cab?
I went to messicks and under the diagrams from the B2650 you can search "washer" it will find all of them.
Check out 110,120
Kubota B2650HSDC (Hydrostatic Transmission, 4wd / Cabin) Parts Diagrams
Kubota Parts Catalog Lookup. Buy Kubota Parts Online & Save!www.messicks.com
That’s what my thought was when I saw it too!Just a silly thought…what type of building is it? Looks like washers used on screws for metal buildings/roofs. The one in the picture doesn’t look like it was ever installed on anything. Most times you will see a witness mark in the washer where a bolt or nut was tightened against it and/or the rubber seal would be deformed some from tightening. The washer in the picture looks unused to me
Might be from tractor deck mounts??I know this is a long shot, but anyone recognize what this washer could be off of? One side is lined with rubber. Found it on the floor after backing the B2650 out of a building. I don't know for sure if it's from the B2650, but it seems likely.
Hello PA452,I know this is a long shot, but anyone recognize what this washer could be off of? One side is lined with rubber. Found it on the floor after backing the B2650 out of a building. I don't know for sure if it's from the B2650, but it seems likely.
Good point. The part in question appears to be 1 1/8" to 1 1/4" diameter. TEK screw washed are mostly 5/8". Well, everyone love a mystery. Let's see who solves this one!I have a metal skinned garage and the washer looks way to big for that.
