A month ago I was chasing a problem and adjusting the governor. I found that I could enrichen the mixer and make it spew black smoke under load as well as lean it so there was no smoke, nor power under load. I then set it back to the original setting where it gives a little grey smoke under load.
Is there a recommended way to set this?
I have a wideband O2 sensor and am thinking that I could set the a/f to say 14:1 to 16:1 under load... would this be a diesel technique to use?
